I have a 5 mega pixel camera and only print 10 x 15 cm. I don’t do a lot of cropping either.
If I need to save memory card space and want to shoot at a lower resolution, how low could I go before the print quality will deteriorate? I also have a choice between ‘Fine’ and ‘Standard’ Quality. Should I stick to ‘Fine’ which also takes up more space, but the quality is higher.
My choices are 2560x1920; 2304x1728; 2048x1536; 1600x1200; 1280x960; 640x480
Quality ‘Fine’ or ‘Standard’
Minimum Resolution For Quality 10x15
Started by jhnel, Feb 17 2006 02:12 PM
Posted 18 February 2006 - 01:52 AM
The general rule for printing photo quality is use around 300dpi ( dots per inch ).
15 x 10 cm equates to about 6 x 4 inches so that means you need a resolution of 1800 x 1200. or above. Even the setting below this is probably good enough.
The fine or medium setting is a personal choice. A few years ago I bought a camera with these settings and could not see any visible difference in quality. Thinking that therewas a fault with the camera I phoned the shop where I purchased and they referred me to the manufacturer.The manufacturer could not tell me what the difference was but advised me to use the lesser setting as I would not be able to see any visible difference. Very strange. As far as I am aware the difference is in the way the camera processes the image. The difference will probably only be noticable under certain photographic conditions, but in general, and at the size you are printing, the medium setting will produce great results.
Hope this helps.
donmac
Hope this helps.
donmac
Posted 18 February 2006 - 04:42 AM
QUOTE (donmac @ Feb 18 2006, 01:52 AM)
Hope this helps.
donmac
Hope this helps.
donmac
Thanks a lot!
