Hello all.
Actually have two topics here.
I have a Zeiss jena DDr 2.8/50mm and a Zeiss Jena DDR 1.8/50mm Pancolar both with M42 thread. One of the sellers of the lens also sells an adapter to fit EOS. I cannot get infinity focus on either lens with this adapter, and when set to infinity with the Pancolar, the mirror hits the back of the lens (as I suspected)
Does anyone have experience of this problem, particularly the lack of infinity focus? Comments much appreciated.
As (I'm told) these are good lenses, which is the best Pentax model (or others) that would suit. I'm a bit shy of trying anything that these lenses were NOT made for after the disappointment of the Canon. Comments much appreciated.
Fidgety
M42 Lenses ..... Which Camera To Match?
Started by Fidgety, Oct 06 2007 05:20 PM
6 replies to this topic
Posted 07 October 2007 - 10:24 AM
LUCKY YOU!!!
The M42 lenses are of a legendary heritage thanks for Zeiss, and their ultra fine optics. They present some of the best in terms of contrast and sharpness.
Leica was a use user of the M42 before switching to the M39.
All old photographers used these in their range-finders. Cartier-Bresson, Friedlander, Winnograd, all had one of their Leicas.
Here's a list of screw-mount Pentax cameras:
Pentax AP
Pentax K
Pentax S
Pentax S1 / H1
Pentax S1a / H1a
Pentax S2 / H2
Pentax S3 / H3
Pentax SV / H3v
Pentax Spotmatic
Pentax SL
Pentax Spotmatic II
Pentax SP500
Pentax SP1000
Pentax Spotmatic F
Pentax Electro Spotmatic
Pentax ES
Pentax ES II
At one time, even Nikon and Canon used the M42 mount. The Russian Zenit and Zorki both used it as well.
Good job on the find. Its a fantastic lens.
I recommend the Pentax Spotmatic. Its cheap, but it is sturdy and reliable, and will last for a long time.
As for the lack of infinity focus, well, you said it! The lens hits the mirror! The problem is because of the adaptor just converts the mount, but doesn't take into consideration the lens thread that extends to the back. The M42 can have an adapter that works on the Nikon range, as I've used one.
The older SLRs had a deeper body, hence why the lens mount works.
Pentax AP
Pentax K
Pentax S
Pentax S1 / H1
Pentax S1a / H1a
Pentax S2 / H2
Pentax S3 / H3
Pentax SV / H3v
Pentax Spotmatic
Pentax SL
Pentax Spotmatic II
Pentax SP500
Pentax SP1000
Pentax Spotmatic F
Pentax ES
Pentax ES II
Posted 07 October 2007 - 02:36 PM
Thanks for all that info!! The 2.8/50mm will not focus to infinity either, although it does not hit the mirror. I am assuming that is because the adapter is the wrong thickness??
Having used EOS with EF lenses, I'm tempted to go back to basics with "Old style"stuff - considering you can buy excellent lenses with no frills at a fraction of the equvalent auto this and that lenses.
Fidgety
Fidgety
Posted 08 February 2008 - 03:32 PM
QUOTE (Fidgety @ Oct 7 2007, 02:36 PM) <{POST_SNAPBACK}>
Fidgety
Fidgety
If you want to have some fun with these lenses on the 'cheap' ...I think the Zenit cameras take M42 thread, they are very basic, built like a tank, but can produce very reasonable results.
Regards
Steve
You don't take a photograph, you make it. - Ansel Adams
Posted 21 February 2009 - 05:39 PM
Just to correct the completely erroneous information provided by 'Fizz': Leica, Canon and Nikon never produced camera bodies with the M42 mount.
The M42 screw mount was first used on the Contax S, designed before World War 2 by Zeiss Ikon but not released until after the war by the Dresden factory, which was then in the Russian sector of Germany, also known as "East Germany". Edixa in West Germany adopted the mount in the early 'fifties and Pentax some time after.
The following site has a fairly comprehensive list of the camera models that were fitted with this mount: Screw Mount (Praktica/Pentax M42) Cameras
I hope that this clarifies the situation for other readers.
Posted 02 March 2011 - 02:42 PM
QUOTE (Fidgety @ Oct 6 2007, 05:20 PM) <{POST_SNAPBACK}>
Hello all.
Fidgety
Fidgety
The old Praktica 35mm slr cameras used 42mm thread lenses...that might be another option...not too expensive either!
Posted 14 April 2012 - 01:16 PM
Something you may want to try are the Fuji (often Fujica) st series.
I have a collection of M42 fit cameras, ranging from a Zenit B, Praktica LLC and MTL5b, but my favourite is the Fujica ST705. Beautifully made and Open Aperture metering with the correct lenses (Just bought an Adaptal2 M42 Fujica mount. Not cheap but worth it,) this camera feels really good to use. Never liked the Pentax Spotmatic. No real reason, just don't. Same as I liked the feel of the Samsung NX10, but not the Panasonic G2. The latter's a good camera, but I hated the feel of it.
Fujica ST705
Nearly all M42 mount lenses will fit on nearly all M42 cameras. There are a few lenses that protrude too far into the throat of the camera, but they're mainly early rangefinder lenses.
I actually have a couple of 35mm EOS cameras and have successfully used a wide range of M42 lenses on them and have never had the problem of focusing to infinity. If your lenses came from a rangefinder camera, the smaller flange depth (of the rangefinder camera) may explain the problem.
Fujica ST705
