I need software to calibrate my monitor and create an ICC profile for my Epson 2200 printer. What should I use. I have seen several packages out there but don't know which will give me the best results. I don't mind spending the money but I want the best value for my buck.
Suggestions?
What Software For Calibrating Monitors
Started by MrGabb, Mar 08 2005 12:41 PM
Posted 10 March 2005 - 01:07 AM
I have the "eye-one" system and use it with the Epson 2200 also. If you can afford it, this works well and I have no complaints.
Go here to the web site;
http://na.eye-onecol...uItemID/134.htm
dennis
dennis
Posted 29 December 2005 - 09:53 PM
Hi there, I can't comment on calibrating your printer, but from my experience I would strongly recommend looking at the products ColorVision make. At the minute I calibrate my monitors using their Spyder2 PRO hardware and software and the results are much better than anything I've had before.
I know my advice might not be particularly useful for your needs but ColorVision do make a system that will calibrate your scanner, printer and monitor for you - I guess you should check that out.
