Canon I905d
#1 salza
salza
Posted 19 September 2005 - 10:20 PM
dry.gif Can anyone please tell me if there is any way that i can make the inner circle smaller than -10.0 when using cd label print. If i print onto dvd disc i am left with a white ring round the inner circle sad.gif
#2 zoe c
zoe c
Posted 01 May 2006 - 04:27 PM
Not sure if I am understand your issue completely, but had a similar problem when using CD LabelPrint. The standard paper size means the smallest you can get the inner circle is (using-10mm) 33mm, which leaves a white ring as you describe. However, if you create your own paper size (from the menu choose File, Select Paper, then choose New from the pop-up window), you can make the inner circle 17mm. 17mm seems to be the smallest the software will allow.
Hope that helps.
